Reset Sync Time Problem
Hi team, we’ve encountered a critical issue regarding our recent connection update. Upon updating, the sync timestamps were reset without any prior notification or warning prompt. Consequently, the next trigger initiated a full replication across several tables, which inadvertently exhausted our entire monthly quota. Since the UI provided no indication that a reset would occur, we believe this was an unintended system behavior rather than a configuration error on our part.
Tables & Run IDs Examples:
  • csh_blocklist: 309885677
  • csh_informacaosmatricula: 309885737
  • csh_historicosistemacontrato: 309885629
  • csh_faixacomissao: 309885599
  • csh_pendencia: 309885594
  • csh_usogarantia: 309885591
  • csh_statusocorrencia: 309885555
  • csh_historicocaptura: 309877929
  • csh_gestaocaptura: 309877928
  • csh_gestaocarteira: 309877927
  • csh_integracaobiometria: 309877924
  • csh_tranche: 309877784
  • csh_checklistcontrato: 309885093
  • csh_scoreproposta: 309885091
  • csh_relatorio_conversa_omnichannel: 309884914
  • csh_proponente: 309876942
  • csh_parametro: 309894199
  • csh_parametrotaxa: 309878667
  • csh_itemblocklist: 309878548
  • csh_logativacaocampanha: 309877027
  • csh_classificacaodaproposta: 309877033
  • csh_imovel: 309878229
  • csh_analiseimovel: 309877087
  • csh_desembolso: 309877158
  • invoice: 309877159
  • csh_imovelxcliente: 309877161
  • campaign: 309877222
  • systemuser: 309876943
