The goal of this question is:
- To validate whether this is possible with Skyvia
- If it is possible, has anyone here tried to do something like this or do you have any recommendations to point me in the right direction in terms o the approach?
Im new to Skyvia and looking at a way to build a bi-directional sync between ASANA tasks and JIRA issues. Our org is a heavy user of ASANA currently but our technical resources have a need to migrate into JIRA. Im looking for a way to reduce the friction iand hopefully remove the need for ASANA users to change how they interact with the technical team.
Is this something that would be technically feasible with Skyvia? I see some other automation platforms that have already done the heavy lifting by building out purpose built syncs between JIRA and ASANA.
I would really like to use Skyvia however, even if the learning curve to achieve this is steep.
