Skyvia Help Resources - Documentation, Tutorials & Support
Collection of Skyvia Help Resources
This article provides a quick reference to all official Skyvia resources. Use the guide below to find the right resource for your task.
Official Resources
  1. Documentation - Technical reference covering all Skyvia products: Data Integration, Backup, Query, and Connect. Start here for configuration guides, field descriptions, and API references.
  2. Support Portal - Submit support tickets, browse the Knowledge Base, and access community discussions. Use this when documentation does not resolve your issue.
  3. Blog - Articles on integration use cases, connector spotlights, and platform updates. Useful for discovering new workflows and best practices.
  4. Webinars - Recorded and live sessions covering specific platform features and real-world integration scenarios. Recommended for onboarding and feature deep-dives.
  5. YouTube Channel - Step-by-step video demos of Skyvia products. Useful for visual learners and quick feature overviews.
  6. Integration Gallery - Pre-built integration templates for the most common source-target combinations. Use it as a starting point to configure your own integrations faster.
  7. Reference Materials - Additional learning resources, including guides and best practices for data integration workflows.
Quick Reference: Which Resource to Use
TaskResource
Configure a connector or mappingDocumentation
Troubleshoot an errorKnowledge Base / Support Portal
Learn about a feature visuallyYouTube / Webinars
Find a ready-made integration templateGallery
Stay updated on platform newsBlog
Still Need Help?
If none of the resources above resolve your issue, submit a support ticket with a detailed description, and we will assist you directly.
    • Related Articles
    • Skyvia Query: Verify Data in Your Connection
      Overview Skyvia Query allows you to browse and verify data in any connected data source directly from the Skyvia interface, without writing complex scripts or using third-party tools. You can use the visual Builder view or write custom SQL ...
    • Troubleshooting Zendesk Backup Issues in Skyvia
      Overview When setting up automated backups in Skyvia, some users may encounter errors that interrupt the backup process. A common example involves two specific errors: "You do not have access to this page. Please contact the account owner of this ...
    • Account and Workspace Roles in Skyvia
      Overview Skyvia distinguishes between two levels of roles for team collaboration: Account roles define what a user can do at the account level: subscriptions, payments, users, and workspaces. Workspace roles define what a user can do inside a ...
    • How to Check if a Column Supports Native Filtering in Skyvia
      Overview Filtering helps make your integrations and backups faster and lighter by reducing the amount of data Skyvia pulls from your source. However, not all objects and fields support native filtering. If a column does not support native filters, ...
    • Skyvia IPs for Whitelist
      Overview Skyvia is a cloud-based platform that connects to your data sources and targets over the internet. If your database, server, or cloud service restricts inbound connections by IP address (e.g., via firewall rules, security groups, or ...
