Fix HubSpot hapikey Permission Error in Skyvia
HubSpot: hapikey Permission Error
This error is common when working with HubSpot and indicates that the API key (hapikey) used for authentication does not have sufficient permissions to access one or more HubSpot objects.
Root Causes
The error typically occurs for one of the following reasons:
  • The account does not have access to the Marketing or CRM portal due to HubSpot subscription limitations and is limited to the Developer portal only.
  • The account does not have access to specific areas within the Marketing Hub.
Resolution
Remove the restricted objects from your backup or integration configuration. Only include objects that are accessible under your current HubSpot subscription.
Additional Resources
For more context, refer to the following HubSpot Community threads:
