Skyvia Query: Easily Verify Data in Your Connection!
Please follow the steps below to query your data in Skyvia Query:
- Log in to Skyvia and navigate to + Create New → Query.
- Select an existing connection or establish a new one for your data source.
- Choose the desired table or object from the Connection Object List.
- Use the Builder view to visually select columns, apply filters, sort, and aggregate data, or switch to SQL view to write custom SQL statements.
- Run your query and immediately review the results.
With just a few clicks, you can efficiently access and analyze your data!
The Free Skyvia Plan allows up to 5 queries per day. Check out the full pricing details
here.
Related Articles
How to Check if a Column Supports Native Filtering in Skyvia
Filtering helps make your integrations and backups faster and lighter by reducing the amount of data Skyvia pulls from your source. However, not all objects and fields support native filtering. If a column doesn’t support native filters, applying a ...
A Quick Guide to Importing and Updating Audience Members in Mailchimp
If your integration involves importing data into Mailchimp Audiences, this information might be helpful. To start, let’s take a quick look at how the UPSERT operation works: If the Id is specified, the integration attempts an Update operation even if ...
A Comprehensive Guide on Backing Up Association Data with Skyvia
Are you looking for a way to back up association data of your data source? Perhaps you're concerned about losing important relationships between records in case of data loss or migration. In this article, we'll explore the process of backing up ...
Integration Failure Types in Skyvia Data Integration
When using Skyvia Data Integration product, you may encounter two distinct types of integration failures: 1. Record-Level Errors These occur when one or more individual records fail to process during an integration task. For example, in operations ...
Data Integration: You have reached the limit of records
The error "You have reached the limit of records" usually occurs when the number of records exceeds the limit specified in your current Data Integration product plan. To resolve this issue, you have a few options: Upgrade your plan to increase the ...
