Skyvia IP Addresses for Firewall Whitelist
Skyvia IPs for Whitelist
Skyvia is a cloud-based platform that connects to your data sources and targets over the internet. If your database, server, or cloud service restricts inbound connections by IP address (e.g., via firewall rules, security groups, or database-level allowlists), you must explicitly whitelist Skyvia's IP addresses to allow the connection.
Skyvia IP Addresses
Skyvia accesses your server from one of the following IP addresses:
  • 40.118.246.204
  • 13.86.253.112
  • 52.190.252.0
Important: All three IP addresses must be whitelisted. Skyvia may use any of them depending on server load and availability. Whitelisting only one or two IPs may result in intermittent connection failures.
Where to Apply
Depending on your infrastructure, add the IP addresses above to:
  • Firewall rules - on your network perimeter or hosting provider
  • AWS Security Groups - as inbound rules for your EC2 or RDS instance
  • Database-level access lists - e.g., MySQL GRANT ... FROM '40.118.246.204', PostgreSQL pg_hba.conf
  • Cloud service allowlists - e.g., Salesforce Trusted IPs, Google Cloud Armor, Azure firewall
Still Having Connection Issues?
If you have whitelisted all three IP addresses and still cannot connect, please contact Skyvia Support with your connection name and the full error message.
    • Related Articles
    • MySQL: Lost connection to MySQL server during query
      Overview The error Lost connection to MySQL server during query occurs when the connection between Skyvia and the MySQL server is dropped while a command is being executed. This typically happens when processing large datasets or when server-side ...
    • SQL Server: Execution Timeout Expired
      Overview The error Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding occurs when a SQL Server command takes longer to execute than the configured timeout limit allows. This is ...
    • Connecting to Amazon RDS from Skyvia
      Overview Skyvia supports Amazon RDS databases. You can connect MySQL, PostgreSQL, or SQL Server hosted on Amazon RDS to Skyvia. To create a connection, go to + Create New → Connection → Database and select the required database type. Before ...
    • Skyvia Query: Verify Data in Your Connection
      Overview Skyvia Query allows you to browse and verify data in any connected data source directly from the Skyvia interface, without writing complex scripts or using third-party tools. You can use the visual Builder view or write custom SQL ...
    • A Quick Guide to Importing and Updating Audience Members in Mailchimp
      Overview This article explains how to configure an UPSERT operation for the Mailchimp ListMembers object in Skyvia. This is the recommended approach for importing and updating Audience members without creating duplicates. How UPSERT Works for ...
