Back Up Association Data with Skyvia - Complete Guide
A Comprehensive Guide on Backing Up Association Data with Skyvia
Are you looking for a way to back up association data of your data source? Perhaps you're concerned about losing important relationships between records in case of data loss or migration. In this article, we'll explore the process of backing up association data using Skyvia.
Understanding Association Data
Association data refers to the relationships between records in a data source. For example, in a customer relationship management (CRM) system, association data might include the connections between customers, contacts, and accounts. Losing this data can be catastrophic, as it can lead to data inconsistencies and make it difficult to recover from data loss.
Skyvia Backup is a robust feature that supports backing up association data, including record relations. When you create a backup, all data, including related records that form associations, is captured. This ensures that your association data is preserved and can be easily restored in case of data loss or migration.
How to Back Up Association Data
To back up association data with Skyvia, follow these steps:
  1. Log in to your Skyvia account and navigate to the Backup section.
  2. Select the data source you want to back up, such as a CRM system.
  3. Choose the tables backup you want to create, including the associated tables.
  4. Configure the backup settings, such as the frequency.
  5. Start the backup process, and Skyvia will capture all your association data.
Restoring Association Data
When restoring association data with Skyvia, you must select all the necessary related objects to preserve the associations. This ensures that your data is restored accurately and consistently.
Tips and Best Practices
To ensure a smooth backup and restoration process, follow these tips and best practices:
  • Regularly back up your association data to prevent data loss. Use Skyvia's automated backup scheduling feature to save time and effort.
  • Check your backups to ensure they are complete and accurate.
  • Consider using Skyvia's restore/data migration features to transfer your associated data to your system if data was lost.
Backing up association data is a critical step in ensuring data integrity and consistency. With Skyvia, you can easily back up and restore association data, including record relations. By following the steps outlined in this article, you can ensure that your association data is preserved and can be easily recovered.
Note: If you work specifically with HubSpot and need a more focused backup solution, you can also consider SkyBackup. It is designed as a standalone HubSpot backup tool and may be a suitable option if you prefer a dedicated service for protecting your HubSpot data. Both tools can complement each other, depending on how broad or specialized your backup requirements are.
    • Related Articles
    • Skyvia Backup Errors Caused by Salesforce API Requirements
      Skyvia interacts with Salesforce via its API. During a backup operation, you may encounter errors due to certain limitations or behaviors specific to the Salesforce API. For example, when Skyvia performs a backup or replication, it queries all the ...
    • Skyvia Query: Easily Verify Data in Your Connection!
      Please follow the steps below to query your data in Skyvia Query: Log in to Skyvia and navigate to + Create New → Query. Select an existing connection or establish a new one for your data source. Choose the desired table or object from the Connection ...
    • Backup Storage Location
      All your backup data is safely stored in Azure GRS storage in the West US region. We use AES‑256 encryption, an industry-standard cipher, to keep your information secure. Currently, you cannot change the storage location. Storing all backups in the ...
    • Troubleshooting Zendesk Backup Issues in Skyvia
      When setting up automated backups in Skyvia, some users may encounter errors that interrupt the backup process. A common example involves two specific errors: "You do not have access to this page. Please contact the account owner of this help desk ...
    • Resolving ActiveCampaign Backup Errors (403 Forbidden)
      Sometimes, when running an ActiveCampaign backup, users may encounter the following error: The remote server returned an error: (403) Forbidden This happens when the ActiveCampaign API receives too many requests in a short period, especially if ...
