Fix ActiveCampaign 403 Forbidden Backup Error - Skyvia
Resolving ActiveCampaign Backup Errors (403 Forbidden)
Sometimes, when running an ActiveCampaign backup, users may encounter the following error: The remote server returned an error: (403) Forbidden
This happens when the ActiveCampaign API receives too many requests in a short period, especially if Accounts, Contacts, or Deals tables contain numerous records.
Cause of the Error
Skyvia supports custom fields for Accounts, Contacts, and Deals in our hybrid implementation.
When the Use Custom Fields option is enabled, Skyvia sends an additional API request for each record to fetch custom field values. This can overload the ActiveCampaign API, resulting in 403 Forbidden or Timeout errors.
How to Resolve it
1. Disable Custom Fields - If you don’t need custom fields, it’s recommended to disable them:
  1. Open your ActiveCampaign connection settings in Skyvia.
  2. Turn off the Use Custom Fields option.
  3. Save the connection and rerun the backup.
This reduces the number of API requests and prevents 403 errors.
2. Exclude Custom Fields from the Backup: If you only need standard object data, exclude custom fields from the backup selection - to reduce API load and prevent errors.
By following these steps, you'll be able to resolve backup issues with ActiveCampaign and ensure smooth data synchronization.
    • Related Articles
    • Skyvia Backup Errors Caused by Salesforce API Requirements
      Skyvia interacts with Salesforce via its API. During a backup operation, you may encounter errors due to certain limitations or behaviors specific to the Salesforce API. For example, when Skyvia performs a backup or replication, it queries all the ...
    • ActiveCampaign: Exporting Contact Data with Custom Field using ContactCustomFieldValues table
      You can export contacts with a specific custom field value to a CSV file using the Advanced Task Editor Mode in a Skyvia Export integration. Steps Create a new Export integration. Open it and switch to Advanced Task Editor Mode. Add an Execute ...
    • Working with Mailchimp Custom Merge Fields
      In some scenarios, you can encounter difficulties with accessing custom Mailchimp fields. To access custom (merge) fields, please follow these steps: Open your Mailchimp connection and ensure that "Merge Fields Behavior" is set to "Join All Merge ...
    • Salesforce API errors: TotalRequests Limit Exceeded/ApiBatchItems Limit Exceeded
      The TotalRequests Limit Exceeded and ApiBatchItems Limit Exceeded errors are Salesforce-specific errors indicating that you have reached specific API limits on the Salesforce platform. Please find explanations of each error and relevant documentation ...
    • Backup Plan Storage Limits
      Overview Each Skyvia Backup plan includes a fixed storage quota. Once this limit is reached, no further backups - whether scheduled or manual - will be executed until storage is freed or the plan is upgraded. Autoclean Availability by Plan Plan ...
