BigQuery: Does not have storage.buckets.get access to bucket default
This issue stems from limitations in Google BigQuery and occur because the default Cloud Storage Bucket is used in your BigQuery connection.
Note, the default bucket is not suitable for operations conducted via the BigQuery API.
Please try creating and using a different bucket for your connection instead. This information may also be useful.
Related Articles
Backup Plan Storage Limits
Overview Each Skyvia Backup plan includes a fixed storage quota. Once this limit is reached, no further backups - whether scheduled or manual - will be executed until storage is freed or the plan is upgraded. Autoclean Availability by Plan Plan ...
Backup Storage Location
All your backup data is safely stored in Azure GRS storage in the West US region. We use AES‑256 encryption, an industry-standard cipher, to keep your information secure. Currently, you cannot change the storage location. Storing all backups in the ...
HubSpot: hapikey Permission Error
This issue is common when working with HubSpot. It typically occurs for the following reasons: The customer does not have access to the Marketing or CRM portal due to HubSpot subscription limitations and is limited to the Developer portal. The ...
UPDATED: Salesforce: Expired access/refresh token
Overview If you see an "expired access/refresh token" error, your Salesforce OAuth connection is invalid. This happens when the token has expired, been revoked, or invalidated by a Salesforce security policy change. Possible Causes The OAuth token ...
📊 Skyvia Data Flow Logs Explained: The Reason Errors and Successes Aren't Shown by Default
In Data Flow, tracking execution success or failure can be challenging due to the nature of row processing. Rows that fail in one component may succeed in another, complicating error detection. By default, Skyvia logs do not provide detailed error or ...
