Fix HubSpot Data Type Conversion Errors in Skyvia
HubSpot '<value>' was not recognized as a valid <DataType> errors in Skyvia
Type conversion errors occur when a value stored in a field does not match the current data type definition. Typical error format:
These errors are generated when the source system returns or stores values that cannot be converted into the expected type.
This issue usually occurs due to a mismatch between historical data and the current field type definition in the source system (e.g. HubSpot or other connected applications).
Common scenarios:
  1. Field type was changed after data was already stored
  2. Legacy records still contain values in old format
  3. Source system allowed inconsistent or free-text values previously
  4. Data was imported without strict type validation
Common pattern:
All errors in this category follow the same structure:
  1. a value incompatible with the field data type
  2. a record identified by Table, Column, and Id
  3. a fix requiring updating the value to a valid format
1. Boolean conversion error:
'undefined' was not recognized as a valid Boolean: [Table: "Table_Name", Column: "Column_Name", Id: 'xxxxxxxxxxxxxx']
Cause:
The Boolean field contains an invalid value ('undefined').
This typically happens when the field type was changed from string to Boolean and existing values were not updated.
Although HubSpot defines this field as Boolean (allowed values: true or false), older records may still contain invalid values due to historical data inconsistencies.
Resolution: Update the field to a valid Boolean value. You can do this either in the HubSpot UI or via Skyvia using the following query:
UPDATE Table_Name
SET "Column_Name" = false
WHERE id = xxxxxxxxxxxxxx
2. DateTime conversion error
'хх/хх/хх' was not recognized as a valid DateTime: [Table: "Table_Name", Column: "Column_Name", Id: 'xxxxxxxxxxxxxx']
Cause:
The field contains a value that does not match the expected DateTime format.
This often happens after changing a field type from text to DateTime, while legacy values remain unchanged.
Resolution: Update the field with a valid DateTime value:
UPDATE Table_Name
SET "Column_Name" = 'yyyy-mm-dd'
3. Double (numeric) conversion error
'ххх' was not recognized as a valid Double: [Table: "Table_Name", Column: "Column_Name", Id: 'xxxxxxxxxxxxxx']
Cause:
The field contains a non-numeric value (e.g. text or formatted numbers) that cannot be converted to Double.
This typically happens when numeric formatting rules changed after data was already stored.
Resolution: Update the field with a valid numeric value:
UPDATE Table_Name
SET "Column_Name" = 0
4. Int64 conversion error
'1234567.0' was not recognized as a valid Int64: [Table: "Table_Name", Column: "Column_Name", Id: 'xxxxxxxxxxxxxx']
Cause:
The field contains a decimal or string value that cannot be converted to an integer (Int64).
This usually happens when numeric values were changed after data was already stored.
Resolution: Update the field with a valid integer value:
UPDATE Table_Name
SET "Column_Name" = 1234567
Notes:
Some invalid values may not be visible in the UI but still exist in the database.
Connector validation prevents new invalid values, but historical data may still contain them.
This is a common scenario when field types are changed in source systems.
All errors in this category indicate the same root cause: the stored value does not match the current data type of the field.
Updating the affected record with a valid value resolves the issue.
    • Related Articles
    • Skyvia Backup Errors Caused by Salesforce API Requirements
      Skyvia interacts with Salesforce via its API. During a backup operation, you may encounter errors due to certain limitations or behaviors specific to the Salesforce API. For example, when Skyvia performs a backup or replication, it queries all the ...
    • HubSpot: hapikey Permission Error
      This issue is common when working with HubSpot. It typically occurs for the following reasons: The customer does not have access to the Marketing or CRM portal due to HubSpot subscription limitations and is limited to the Developer portal. The ...
    • Integration Failure Types in Skyvia Data Integration
      When using Skyvia Data Integration product, you may encounter two distinct types of integration failures: 1. Record-Level Errors These occur when one or more individual records fail to process during an integration task. For example, in operations ...
    • HubSpot: 414 Request-URI Too Large & 400 Request Header or Cookie Too Large
      This error occurs when the object you are querying contains too many custom fields. To resolve this issue for ContactListContacts, Contacts, and Deals objects, enable the Column-wise chunking option in the HubSpot connection editor (located under ...
    • Skyvia Query: Easily Verify Data in Your Connection!
      Please follow the steps below to query your data in Skyvia Query: Log in to Skyvia and navigate to + Create New → Query. Select an existing connection or establish a new one for your data source. Choose the desired table or object from the Connection ...
